Export Time Limit
COW Forums : Media 100 844/X
Thomas Eldred
Export Time Limit
on Nov 19, 2008 at 5:11:01 pm
Is there a limit (time or size)as to how much the 844x system can export at one time. The range of the timeline is hour and a half. Do we need to break it up into two sections or try something else?
Floh Peters
Re: Export Time Limit
on Nov 19, 2008 at 5:12:54 pm
It depends on which codec you intend to use. There are many codecs and formats that only support 2GB or 4GB filesizes, so you should avoid these.
Thomas Eldred
on Nov 19, 2008 at 5:34:14 pm
We are exporting to a quicktime movie, with the 844x codec. The finished file will be converted in Cleaner and create a DVD in Encore versioon 1.
Floh Peters
on Nov 19, 2008 at 5:35:56 pm
This should work. On the other hand, 1.5 hours is pretty long for an uncompressed codec, and as far as I can remember 844/X has not been too stable on QuickTime exports. I would recommend breaking it up into 2 segments if possible.
Thomas Eldred
on Nov 19, 2008 at 5:40:45 pm
Sounds like a winner! Thank you for help.
