V-LAN Driver Download failed
COW Forums : Media 100 844/X
Ronan O hEidhin
on Nov 7, 2008 at 8:31:58 pm
When I choose the V-LAn Driver DVW-500,510 in Device Setup, it tries to down load it but fails. I would realy appreciate it if someone could help with this problem,
Ronan
Rónan Ó hEidhin
Re: V-LAN Driver Download failed
on Nov 17, 2008 at 11:27:06 am
Help me please I'm drowning....
R
Floh Peters
on Nov 17, 2008 at 11:34:57 am
One thing you should check is if your hardware is okay. Do run the hardware diagnostics, since the VLAN module is a separate piece of hardware on one of the boards. If you did not change anything on your system it could be possible that your V-Lan module went bad.
Other than that, you could delete the 844/X prefs to see if this changes anything.
Does any of the V-Lan drivers load correctly, or do they all fail?
Ronan O hEidhin
on Nov 17, 2008 at 2:18:05 pm
Hi Floh,
Thanks for your reply. I'm going to have a look at what you sugested now, as regards your question- none of the VLAN Drivers load up. Thanks.
Ronan
R
Rónan Ó hEidhin
on Nov 18, 2008 at 4:07:19 pm
Just an update. Hardware Diagnostic suggests all is fine. Boards re-seated and the problem remains the same. Mmmmm....
Ronan
R
Wickham Strub
on Nov 18, 2008 at 5:08:52 pm
Rónan,
Send me an email at support@media100.com.
I've got an idea that's an EXTREME long shot.
~Wick
Rónan Ó hEidhin
on Dec 15, 2008 at 8:43:50 pm
Muchos Gracias Wick,
up and running again for the Christmas schedule.
Thanks again.
Rónán
R
