Replace Raid with firewire??
COW Forums : Media 100 844/X
Jack Morgan
on Apr 24, 2008 at 5:42:27 pm
Floh... Is it possible to replace the raid with a fire wire drive ? Looking for a cheap fix until the FInal Cut system is in place... The band width seems to be there... or is the 844x hardware wire to work only off SCSI? Thanks, Jack
jmorgan
DeadLine Productions
Houston, Texas
Floh Peters
Re: Replace Raid with firewire??
on Apr 24, 2008 at 5:56:33 pm
The 844/X software is looking for video drives on a special PCI-bus only, so I think you are out of luck with FireWire. Additionally, if the 844/X does not get its video data in time it will not be happy. Unfortunately you would not only get performance warnings, but you could expect system freezes and crashes, so I think it would not be a good idea to try this.
Jack Morgan
on Apr 24, 2008 at 6:02:01 pm
Floh, thank you for your quick response... we did try it just to see what would happen and you are right it does not like it. I will have to look for an economical SCSI solution. Thanks again for being out there! Jack
jmorgan
Houston, Texas
