RAID Issue
COW Forums : Media 100 844/X
Elliott Dunwody
RAID Issue
on Mar 17, 2008 at 3:53:41 pm
Our rock solid 844X has a issue with the RAID Array that came with it.
It is flashing Red after about 15min and beeping. We can still access it though.
Any thoughts?
Elliott
Bright Blue Sky Productions
4811 Rivoli Dr
Macon, GA 31210
http://www.brightbluesky.com
Floh Peters
Re: RAID Issue
on Mar 17, 2008 at 4:42:09 pm
If this always happens after some time I would guess that a fan is not working correctly, therefore the temperature is rising into a warning limit. You should check the fans; if you have the manual, look up what this blinking is supposed to mean. If you donĀ“t have the manual, maybe google for it.
Elliott Dunwody
Re: RAID Issue
on Mar 17, 2008 at 8:47:21 pm
Looks like my drives are getting old. I am getting a "at risk" message.
Any other newer type drives available for that system?
Elliott
4811 Rivoli Dr
Macon, GA 31210
