FLT light flashing on drive unit.
COW Forums : Media 100 844/X
Al J. Marschke
on Jan 16, 2008 at 2:30:55 pm
There is a red light flashing labeled S-FLT. I assume fault. The unit is one of the earlier arrays. 10 bay of 73GB 10,000 rpm seagates. JBOD. It's the S-FLT light between the two SCSI connector cables. It has a S-LINK port to the right of it. Not sure if it's a controller fault or a drive fault.
There is a green light opposite of it that reads S ACT. The green light is NOT lit.
Any ideas?
dmistu
Re: FLT light flashing on drive unit.
on Jan 21, 2008 at 12:19:26 am
We've had exactly the same problem with our system. Identical set up with 10x 73Gb drives in the Raid setup and the same FLT red light now flashing on the back of the hard drive case unit.
Any help would be appreciated.
Al J. Marschke
on Jan 21, 2008 at 3:01:24 pm
This is what I have learned:
That S-FLT light blinking red indicates that your SAF-TE processor is functioning OK. The flashing light is a normal indication. If the light stays solid red or not flashing, then you have a problem with the SAF-TE processor.
Beam me up. Kirk out.
