A Working Back-up Solution... and a question
COW Forums : Media 100 844/X
Robert Griffiths
on Oct 14, 2007 at 6:14:50 pm
Hi all,
I just got done installing a back-up solution into my 844/x and I am please to tell you that it works... so far. Here are the components:
- A standalone Granite Digital Aluminum Rack Mounted Dual Drive Unit
- Silicon Image SATA card from granite Digital into my 844/x
- See at http://www.granitedigital.com/catalog/pg61_alumhotswap2-4-8rack.htm
There was only one slot left in my machine... the one in between the 2 844/x cards. I ginger disconnected the connecting jumper between the 2 cards and slipped the SATA card in between. Fired it up and everything appears OK... including the performance of the 844/x.
My question is: Has anyone ever copied folders of media off their drives onto another storage device and then brought them back? Does the 844/x succesfully link to the copied media files? Obviously, I am hoping that it is seamless.
Here's hoping... Thanks!
G r i f f
R o b e r t G r i f f i t h s , D i r e c t o r
F i r e D a n c e r P r o d u c t i o n s , I n c.
C a r b o n d a l e * C o l o r a d o * U S A
http://www.FireDancer.tv
Ben Heusner
Re: A Working Back-up Solution... and a question
on Oct 15, 2007 at 6:44:15 am
Yes, I've done this many times, and it works fine.
If you want to short-circuit the locate files stuff, then add the folders you've copied back to your Media Search Locations.
Cheers,
Ben
Curious Turtle Professional Video
Training | Editing |Support
http://www.curiousturtle.com
Robert Griffiths
on Oct 15, 2007 at 1:06:22 pm
Cool! Thanks, Ben.
G r i f f
