exporting via quicktime which quicktime version
COW Forums : Media 100 844/X
ESSENTIALFRED
on Oct 10, 2007 at 9:14:49 pm
I am having difficulty with exporting via 844x. Programs over 7-8 minutes in duration either lockup 844 or gives me an error code. I see others have experieinced this problem and was wondering if a solution has been developed.
Also the By-Reference Movie button in the Export window is turned off.
Could the quicktime version be the source of this problem?
We installed version 7 for another application and I am suspicious that 844x only supports earlier versions like quicktime 5. am I right?
Ben Heusner
Re: exporting via quicktime which quicktime version
on Oct 11, 2007 at 12:31:27 pm
This could be a Quicktime issue, or could be the occasional 844/X lockup that happens from time to time.
The last official QT tested was v6.02. QT 7 changed/broke quite a few things with various applications. Most of those apps got updated - 844/X didn't. There are some people working with V7 without any issue, but if you're suddenly experiencing problems with exporting, then rolling back to an earlier version seems like a sound idea.
By-reference only ever turns up when exporting from the Source window. It will only render a self-contained movie if exporting the timeline.
Cheers,
Ben
Curious Turtle Professional Video
Training | Editing |Support
http://www.curiousturtle.com
Jason Kalinoski
on Oct 12, 2007 at 2:14:32 pm
I've always had this problem with anything over 3-4 minutes in length.
Our solution is to capture longform videos over SDI to our FCP station and compress it there. Not perfect, but it works.
Jason
Robert Griffiths
on Oct 14, 2007 at 5:05:29 pm
I have the same issue on longer renders. I find that a restart and turning off the screensaver helps... but isn't perfect. Eventually, I get even the longest ones out but it may take a few tries.
HTH
G r i f f
R o b e r t G r i f f i t h s , D i r e c t o r
F i r e D a n c e r P r o d u c t i o n s , I n c.
C a r b o n d a l e * C o l o r a d o * U S A
http://www.FireDancer.tv
