Need to keep alpha channel on export
COW Forums : Media 100 844/X
Sam Lesante Jr.
on Sep 7, 2007 at 2:07:51 pm
I'm trying to import a file into 844x with an alpha channel (did it successfully) then put it in a timeline and copy and paste the clip a couple of times to make it a min. long then I want to import it into After Effects and then export it from AE as a certain file type I need to have the final animation play on my Compix CG.
So how do I export it out of 844x that will keep the alpha channel?
TIA
Sam
Floh
Re: Need to keep alpha channel on export
by
on Sep 7, 2007 at 2:14:26 pm
If you export as self contained in 844/X codec you should be getting 2 files. The Fill file and a separate Key file. Use the key file in AE as a track matte.
