Export from Edit Suite problem
COW Forums : Media 100 844/X
Clea
by
on Sep 7, 2007 at 10:02:39 am
Sometimes the Export to edit suite function does not highlight - and no settings have been changed, and previously it has worked. for example it worked yesterday, today it didn't. what are the common things that allow this to occur? i need to export a range in the timeline into quicktime - and i just can't get that option to highlight - it just stays grey - thanks
Floh
Re: Export from Edit Suite problem
by
on Sep 7, 2007 at 12:33:51 pm
Most likely you have closed your Edit Suite window. Press CMD-1 to bring it back to the screen.
Floh
by
on Sep 7, 2007 at 12:34:49 pm
[Floh] "Most likely you have closed your Edit Suite window. Press CMD-1 to bring it back to the screen."
Uh, are you speaking about Media 100 i, Media 100 HD or 844/X?
Clea
by
on Sep 7, 2007 at 1:01:05 pm
Hi Floh
Totally new at Media 100 - just had to export these files - thanks so much - of course it worked - appreciate your quick response.
regards
Clea
