XML import from Media 100 HD
COW Forums : Media 100 844/X
Tabbut
on Apr 2, 2007 at 4:03:29 pm
Doing a project where the first cut is done on the M100 HD and then finished on the 844X. First time doing this and as a test took my first rough cut and exported an XML of the timeline (i don't own OMF exchange) and put that into the 844. The timeline made it into the 844 but all of the clips became separate audio and video files which i had to manually re-sync. My best guess is that i need to change a setting but still have not found which one. Also the two systems are at different locations so a direct connect work around is not an option.
Any advice would be greatly appreciated.
Tabbut
