Viewing both XServes
COW Forums : Media 100 844/X
Justin
on Feb 20, 2007 at 5:09:01 pm
I have an Xserve hooked up to my 844x. We later bought two G5s that are hooked up to another Xserve through Qlogics fiber switch. Previously the 844X was going directly to the first XServe via fiber, then I hooked it up through the switch. Everything is still fine but how am I able to see both Xserves from any workstation? I was hoping for the easy plug n play solution. Is it a Mac/PC issue? Thx. I looked on this forum and apple's but couldn't find this problem.
John Twigt
Re: Viewing both XServes
on Mar 2, 2007 at 10:58:58 am
I'm no expert on this, but it seems to me that there should be some SAN-sharing software running to be able to use both RAIDS crossplatform...Are you sure you're not losing speed in the current setup? (as opposed to your old setup with direct access?)
John Twigt
Workstation BV, Amsterdam
The Netherlands
http://www.workstation.nl
