Does the 844X codec work with After Effects 7?
COW Forums : Media 100 844/X
dmistu
on Jan 10, 2007 at 9:39:10 pm
We've just bought a new graphics machine which has the latest version of After Effects 7 on (the profesional bundle)
I've installed the 844X codec on this machine but AFX doesn't seem to be recognising the 844 media files.
Has anybody else had 844X files working in AFX7 or perhaps know for sure that it can't be done?
Many thanks, Stuart
Ben Heusner
Re: Does the 844X codec work with After Effects 7?
on Jan 11, 2007 at 12:36:43 pm
Works fine here.
Can you see the files in Quicktime player? If not, then it's sounds like a simple problem with your installation.
Good luck,
Ben
Curious Turtle Professional Video
Training | Editing |Support
http://www.curiousturtle.com
bodgetastic
on Feb 21, 2007 at 3:43:25 pm
Think so, we've got AE7 on our 844 machine and while I haven't imported yet, I've rendered out to it. If QT pro can see it then aftereffects should...
dmistu
on Feb 21, 2007 at 3:56:32 pm
Thanks for this. Does it have to be Quicktime Pro?
We have AFX7 on a separate graphics machine to our main 844 system. When we move 844 files across to it we can't see them in Quicktime or AFX even though I've installed the 844 codec on this machine.
It's only running the standard Quicktime player and not the Pro version. Do we need QT Pro to see 844 files?
Cheers,
Stuart
Floh
by
on Feb 21, 2007 at 4:04:20 pm
[dmistu] "Thanks for this. Does it have to be Quicktime Pro?"
No. The "Normal" QuickTime Player (Pre V7) should be fine.
