DVfiles to 844x
COW Forums : Media 100 844/X
Marion
DVfiles to 844x
on Oct 5, 2006 at 12:11:51 am
I have 53 clips on a drive in the DV format. I need to use them in an 844x project. When I import them, the field order seems to reverse. The only way I have found to convert them is using AE, but this will take forever to set up each clip. Is there any way to do this as a batch process? Or to change settings in 844x to make this work?
Thanks in advance,
Marion
Marion Abrams
Madmotion, LLC.
Pittsfield, VT.
USA
Ben Heusner
Re: DVfiles to 844x
on Oct 6, 2006 at 3:25:32 pm
Hi Marion,
In the Import window there's a little checkbox for Reverse Fields. Make sure this is checked and it will do away with the need to go to After Effects.
HTH
Ben
Curious Turtle Professional Video
Training | Editing |Support
http://www.curiousturtle.com
Marion
Re: DVfiles to 844x
on Oct 9, 2006 at 3:18:33 pm
Thanks! you're a lifesaver. Thank goodness there are still a few of us left here.
Marion Abrams
Madmotion, LLC.
Pittsfield, VT.
USA
