Insert Editing Continued
COW Forums : Media 100 844/X
Andrew Watt
on Sep 26, 2006 at 10:15:04 pm
I have successfully done a video only insert on to a tape with no audio pop by turning off all the audio outputs in the Master to tape dialog.
However I still can not do an audio insert onto a tape without it dropping a frame of audio. Is this an 844X bug?
Andrew
bouke
Re: Insert Editing Continued
on Sep 27, 2006 at 3:57:07 pm
I have not done it often, but i can't remember having problems.
Do you have the correct machine template?
You're not doing something strange like inserting in pre-read?
(not sure if your machine can do that...)
Does audio also go over SDI? Tried AES?
Bouke
Andrew Watt
on Sep 27, 2006 at 4:25:48 pm
I'm using the DSR 1500 template so that should be ok. Audio is going SDI. I'll give AES a shot.
Andrew
Andrew Watt
on Sep 27, 2006 at 6:46:48 pm
Bouke,
No luck outputting using AES either.
However if I turn off the AES/EBU 1/2 Playback output when insert editing via SDI it still drops a frame of audio but at least it doesn't make a loud pop anymore.
So I guess if I do need to insert audio on to a master in the future I just need to find a silent spot for the in point.
Perhaps this is a limitation of the DSR 1500.
bouke
on Sep 27, 2006 at 8:25:18 pm
If this is a limitation i would sent it back....
Can you try another edit controler or NLE to see if it's the recorder or the 844?
Bouke
Andrew Watt
on Sep 27, 2006 at 8:33:21 pm
Good point, it is not the DSR 1500 because we have the same problem with the DSR 80. it must be the 844X...
