Color Finesse
COW Forums : Media 100 844/X
Robert Griffiths
Color Finesse
on Apr 9, 2006 at 2:29:50 am
Has anyone tried to use Color Finesse with the 844/x? I sure could use some form of white point color correction.
G r i f f
R o b e r t G r i f f i t h s , D i r e c t o r
F i r e D a n c e r P r o d u c t i o n s , I n c.
V e r o n a * N e w J e r s e y * U S A
http://www.FireDancer.tv
Andrew
Re: Color Finesse
on Apr 10, 2006 at 8:49:13 am
Hi Robert,
Doesn't work. Nasty crash.
Wish it did, though. Very handy with AE indeed.
Robert Griffiths
Re: Color Finesse
on Apr 10, 2006 at 10:40:25 am
Too Bad!
Anything out there with white point color correction that behaves itself?
G r i f f
RobCoblentz
Re: Color Finesse
on Apr 10, 2006 at 12:28:32 pm
Check out the 55mm filters. The Windows AE version seems to work with our system.
Robert Griffiths
Re: Color Finesse
on Apr 10, 2006 at 9:07:18 pm
Actually, I'm a big fan of 55mm but I have an older set. (v4.0?) I'm not in front of my 844/x right now. Do they offer a white point color correction filter?
G r i f f
edunwody
Re: Color Finesse ?
on Apr 17, 2006 at 12:18:18 am
Ok, Im not proud, what's white point color correction?
Elliott
Bright Blue Sky Productions
4811 Rivoli Dr
Macon, GA 31210
http://www.brightbluesky.com
Robert Griffiths
Re: Color Finesse ?
on Apr 17, 2006 at 2:07:27 am
Essentially, you tell a piece of software what portion of a picture is suppose to be white. Usually it is done with an eyedropper. Then the software will "reverse engineer" the proper color temperature for the shot. Think of it as a post production white balance. I've seen it work on an Avid and it does a quick, painless job of correcting bad white balance. From what I understand, it was suppose to be in the never released "next" version of the 844/x.
Would love to hear about a compatible plug-in that can do the same thing.
G r i f f
