Bin Issue
COW Forums : Media 100 844/X
Jack Morgan
Bin Issue
on Mar 21, 2006 at 7:46:18 pm
I have a particular bin that I use and have used for a couple of years now for an on going client. There are several clips that show the "media offline" color bars, however when I double click on them they play fine and are usable. I have tried starting a new project and importing it in with no change. I have tried to relink media to the media folder but no luck. Like I say, I can still use the clips but it is curious. Maybe I am not relinking to the right folder of something. Any ideas? Jack
DeadLine Productions
Houston, Texas
Jon Walker
Re: Bin Issue
on Mar 27, 2006 at 10:44:54 pm
This is just a guess, but have you checked your media 100 project settings? This should reveal your save destinations for your media. If you have moved the media recently it may have thrown everything out of whack. Your settings may have gotten reconfiged as well. Worst case scenario, if you have all your project info backed up and media saved on different drives, you could do a clean install and try relinking again if this is a big problem.
© 2018 All Rights Reserved
