White flecks when processing effects.
COW Forums : Media 100 844/X
Espen Olsen
on May 12, 2005 at 1:20:14 pm
I'm having a big problem and I can't seem to sort it out :-(
I am getting white flecks/noise when I process a clip containg filters. The filters are TimeFX and Tonal Correction. It seems to happen at random ... sometimes on only one pass, sometimes on both passes. I have tried every amaginable combination to no awail.
Anyone out there who has seen/solved this?
The 3.0.4 "Customer Notes" mentiones this kind of thing happening when you scale a clip over 400% and using z-rotation...
I am using v 3.0.2 without x-blur.
At one occation I have had this happen with Tonal Correction, but other than that it has worked.
Espen Olsen
Lyd & Bilde as
Oslo, Norway
Dan Geller
Re: White flecks when processing effects.
on May 12, 2005 at 4:21:51 pm
I've had this happen when input sync to 844x is not good. Also, when I had set output sync to genlock this happened. Setting output to internal reset the boards and fixed the problem.
John Buck
on May 20, 2005 at 3:57:11 am
espen
interested in some 844 news?
email me
velocite (at) Gmail.com
john
