how to "delete undo media"?
COW Forums : Media 100 844/X
on Apr 13, 2005 at 3:07:48 pm
I've been working with a 844xe for a few weeks now and have some questions about the system where i can not find any info in the guides that came with the sytem.
I am an Avid cutter so i do presume some things are like a avid sytem. First of all under file there is a command 'delete undo media' this command is not active
and i can't find a way to active it. Also in projects setting you can active 'Limit cache size'. Can anyone help with these commands. Thanks for your help. Christoph.
© 2018 All Rights Reserved
