Need some quick help!
COW Forums : Media 100 844/X
mark in jax
on Apr 4, 2005 at 6:02:22 pm
Thought this would be easy, but.....
Ditched the media for a job, need to rebuild part of it, thought there was a way to recapture from the timeline a selected area or number of clips but couldn't find it so I recaptured the bin instead. Now I have all of the media in the bin but it won't relink with the timeline! I tried to be cognizant of which clips had audio and which didn't since the batch recapture doesn't prompt you on this. I would have thought that even if a few clips were recaptured wrong I would still have the bulk of them but currently I've got NADA! When I use the relink feature it can't find them even when I point to the correct folder. HELP!
Floh
Re: Need some quick help!
by
on Apr 4, 2005 at 6:04:31 pm
If you want the media to relink to the timeline you have to reacquire the timeline, not the bin. There is no way to relink media to a timeline that was reacquired only from a bin. Either you replace the media clip by clip, or you redigitize the media on the timeline.
mark in jax
on Apr 4, 2005 at 6:10:00 pm
Thanx...and to do that I highlite the clips in the timeline I want to recapture and then use the Batch Recapture under File? Or does it want to recapture the entire timeline? I will say that if you rename the file changing the 2 back to 1 it does see it in the timeline...guess I'll just have to figure out which is quicker!
Floh
by
on Apr 4, 2005 at 6:11:28 pm
You e.g. can drag the clips you want to reacquire from the timeline to the batch acquire window.
mark in jax
on Apr 4, 2005 at 6:24:38 pm
ahhh...got it...yea cuz there is no recapture option directly from the timeline that I can see.
Floh
by
on Apr 4, 2005 at 6:26:47 pm
You also can right-click on the timeline in the project window (or select the timeline and bin in the project window and then right-click on one of them) and reacquire everything from there.
mark in jax
on Apr 4, 2005 at 6:35:21 pm
Great tips Floh...and fast too! Thanx a million, you helped me tremendously.
mark in jax
on Apr 4, 2005 at 6:06:54 pm
Well...figured out what happened...it changed a file number from 1 to 2 on each clip when it recaptured...nice.
