FCP 7 - Gaussian Blur Background
FAQ   •   VIEW ALL   •   PRINT   •   NEXT >>
Jake van Vuuren
on Oct 26, 2019 at 8:32:06 pm
Hello Folks,
Anybody has a good tutorial or video on How To Blur the Background of a talking head? Do you even get good results doing this effect in FCP 7? I'm not a Motion expert.
Jake
jakevv
David Roth Weiss
Re: FCP 7 - Gaussian Blur Background
on Oct 26, 2019 at 9:32:02 pm
If your subject moves at all while chatting to camera you’re going to have a tough time, as you’ll probably be rotoscoping, or fixing a zillion keyframes on a frame by frame basis. Adobe has an automated plugin for rotoscoping, but it doesn’t work perfectly, meaning you’d still have to fix many of its mistakes on a frame by frame basis. Shooting with a soft background is NOT one of those things best fixed in post.
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro Legacy forum.
Nick Meyers
on Oct 29, 2019 at 1:08:29 am
a lot depends on how detailed / accurate you want the separation between fg/bg to be.
if you don't want too much detail / accuracy, then FCP7 can do the job.
the basics are pretty obvious
duplicate your clip/s into two layers, say V1, V2, (option short drag a clip upwards to dupe it)
apply a blur or defaces to V1, apply a garbage matte to V2.
it could be as simple as a diopter effect, where there's a simple soft line delineating the bg,
or a more complex shape around your fg subject.
keep the shape loose so you don't have to do a zillion key-frames.
see if you can still find the Paul Crisp garbage metres on line somewhere.
with those you can keyframe the position of your shape as a whole.
makes life a lot easier.
for anything more complex however, you'd need to go outside of FCP7.
Resolve is free, and has these sorts of tools.
cheers,
nick
Mark Suszko
on Nov 8, 2019 at 10:42:44 pm
Yes, when I did this the Paul Crisp multi-point mask tools were a Godsend, especially since they could be feathered. If you do a DEEEP search of the COW archives for Paul Crisp it may turn up still-not-dead link to those masks, which came in 4,6, and 12-point versions, maybe more.
