Lost in the Mojave Desert
David Butterfield
on May 3, 2019 at 1:28:11 am
A well-meaning person updated the OS on my MBP and thus neutralized my cherished FCP 6 and 7. I was still using these classics and have projects there that I need to update or draw from. Before I try some of the partitioning solutions I see here or try to find a computer running an older OS, is there any new editing system or converter you can load these old projects into and still have functional editing? I remember seeing that you couldn't do legacy jobs on FCP X. Is there anything out there will? Thanks.
Michael Gissing
Re: Lost in the Mojave Desert
on May 3, 2019 at 2:46:31 am
If you convert your FCP 6/7 projects to XML they can be loaded into both Premiere and Resolve. Some effects, grades and plugins will need to be redone with newer equivalents. Text generators will come through but formatting & fonts might need a tweak.
Warren Eig
on May 3, 2019 at 4:25:05 pm
Also if you have an XML "SendToX" works great. Opens projects from FCP7 to FCPX.
Warren Eig
O (424) 293-1164
email: info@babyboompictures.com
website: http://www.BabyBoomPictures.com
Vimeo: https://vimeo.com/babyboompictures
For Camera Accessories - Monitors and Batteries
website: http://www.EigRig.com
Shane Ross
on May 3, 2019 at 4:37:33 pm
But yes, ANY solution means getting FCP Legacy installed on a computer with a compatible OS, so you can open it and export what needs to be export.
Shane
Little Frog Post
David Butterfield
on May 3, 2019 at 5:17:31 pm
Key point. I may go ahead with a Time Machine restore. Thanks for your reply.
David Butterfield
on May 3, 2019 at 5:14:59 pm
Thanks, will look into that.
David Butterfield
on May 3, 2019 at 5:14:18 pm
Thank you. Much appreciated.
Mark Ivey
on May 5, 2019 at 2:31:37 pm
VMWare Fusion
Keep your older software and OS running while you can update your computer to the latest OS version if you'd like all without having to reboot to a different partition.
https://my.vmware.com/en/web/vmware/info/slug/desktop_end_user_computing/vm...
David Butterfield
on May 5, 2019 at 4:30:48 pm
Thanks, will look into it. Working on this today.
