FCP7 Crash during Export, Mavericks (10.9.5) Newly installed Hard Drive
Derrick Schweizer
on Sep 19, 2018 at 1:13:36 am
Alright, This is a absolute nightmare. I've had problems when I went to Mavericks 5+(ish) years ago, but through forum sifting and LOTS of trouble shooting I had it running fine in the mean time. Long Story short the S.M.A.R.T. status on my HDD was failing and I had to replace it. Not a problem. I found a guy who did it and put Mavericks back on so I could just use my time machine backup. FCP7 and motion work fine... except when I go to export.They get about halfway before crashing and I've gotten varying degrees of crash reports but all generally say:
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000d0458d11
I can post more of the report if you'd like. I've tried the usual suspects trashing prefs, running disk utility (on external too). I want there to be a fix, I'm even running digital rebellion giving me feedback on the crash reports. I've just been digging... Is there something I don't know about hardware that could have caused this? The drive that he put in here is a 1TB from a 2013 iMac. Mine is an early 2009 model (with updated RAM). Does anyone know anything before I start posting crash reports? I appreciate any help I can get, these threads have always been a tremendous help.
Thank you,
Derrick
Warren Eig
Re: FCP7 Crash during Export, Mavericks (10.9.5) Newly installed Hard Drive
on Sep 19, 2018 at 3:58:29 pm
I've never had luck with using time machine to reinstall programs. Save yourself the hassle and reinstall the FCP suite from the original install disks.
Warren Eig
O 310-470-0905
email: info@babyboompictures.com
website: http://www.BabyBoomPictures.com
Vimeo: https://vimeo.com/babyboompictures
For Camera Accessories - Monitors and Batteries
website: http://www.EigRig.com
Nick Meyers
on Sep 22, 2018 at 9:38:31 am
some questions:
is your timeline full rendered?
is there some media in your timeline (around the halfway mark) that could be causing FCP to struggle, and crash?
I'm thinking large image files.
i has some rather large image files in a project a year or so ago,
and had the same problem, crashing on export.
even when they were rendered!
i took that section into another FCP project, which was much smaller and simpler,
and i was able to render and export from that one,
then i brought that new export into the original project, and laid it over the problem section,
and i was able to export again.
phew ☺
nick
