Problem with freeze in full screen mode (sound is there)
Antoni Beksiak
on Feb 24, 2018 at 12:47:31 pm
The symptoms are generally as described here: https://discussions.apple.com/thread/911467
No video, on stop the frame is updated.
I tried the advice described in the above thread, and I only managed to get another project (with another kind of footage) showing full screen video by reconstructing the FCP7 preferences.
However, on another roughly similar machine the problematic project shows fullscreen video properly.
Thank you in advance.
I'm on an MacBook Air w/macOS Sierra (10.12.6).
Shane Ross
Re: Problem with freeze in full screen mode (sound is there)
on Feb 25, 2018 at 7:50:24 am
FCP 5.0.4 is a LONG time ago, but let's see if the same thing is there that's in FCP 7. VIDEO PLAYBACK>ALL FRAMES? Is that chosen?
Shane
Little Frog Post
Antoni Beksiak
on Feb 25, 2018 at 10:34:15 am
Hi, thanks,
Sorry, I'm on FCP7, I just referred to a similar issue.
Yes, "All frames" chosen.
Nick Meyers
on Feb 26, 2018 at 8:30:24 am
and what format is your source video?
and sequence settings?
is your external video playback setting the appropriate one?
if you're trying to play, for instance, PAL footage out via an NTSC setting, you can get the effect you describe.
nick
Antoni Beksiak
on Feb 26, 2018 at 11:41:06 am
Sorry I didn't add it, forgot while my post was in moderation. The sequence and footage date is as follows:
1920 x 1080, 25 fps, Apple ProRes 422, aspect: square, field dominance: upper (odd)
Sequence settings: HDTV 1080i (16:9)
Regards,
Antoni Beksiak
on Feb 26, 2018 at 11:46:34 am
I'm not sure, however, if I'm checking the external video playback setting correctly, can I ask for a walkthrough?
Antoni Beksiak
on Feb 26, 2018 at 1:35:52 pm
But, the same happens with internal (laptop) screen.
Shane Ross
on Feb 26, 2018 at 5:58:40 pm
Is video playback set to Digital Cinema Preview?
Shane
Little Frog Post
Antoni Beksiak
on Feb 27, 2018 at 10:01:04 am
yes, View > Video Playback > Digital Cinema Desktop Preview - Main or - Full Screen, depending on the screen (monitor)
