XAVC codec
Julie Lewis
XAVC codec
on Jan 26, 2018 at 6:47:51 pm
Hi, -- Just to be sure -- Can FCP 7 edit with XAVC codec? I usually edit in Apple Pro Res. Can I convert XAVC through MPEG streamclip and/or Compressor?
Shane Ross
Re: XAVC codec
on Jan 26, 2018 at 8:21:51 pm
FCP 7 won't work with that codec, won't even import it. Nor will MPEG Streamclip convert it, its development has been discontinued. You'll need something like EDITREADY to convert it to ProRes first, then you should be golden.
Shane
Little Frog Post
Nick Meyers
Re: XAVC codec
on Jan 27, 2018 at 8:03:31 am
would Sony have something for transcoding it perhaps? Catalyst Browse?
Also Resolve may do the trick.
nick
