How upgrade from 10.8.5 to 10.10 or 10.11 mid project?
Dan McGuire
on Aug 22, 2017 at 2:25:47 pm
I've got a FCP7 project on my 10.8.5 system.
I need to re-batch digitize using a teranex, which requires 10.10
Is it too dangerous to switch systems at this point? I don't even have the last version of FCP7 on DVD if the program stops working. I have old program discs that had multiple upgrades from Apple afterwards.
Suggestions?
Warren Eig
Re: How upgrade from 10.8.5 to 10.10 or 10.11 mid project?
on Aug 22, 2017 at 4:27:21 pm
Go get another drive. Clone the current drive to the new drive. Update the new drive so you can go back. This is now a dual boot system. ☺
All is good!
Warren Eig
O 310-470-0905
email: info@babyboompictures.com
website: http://www.BabyBoomPictures.com
For Camera Accessories - Monitors and Batteries
website: http://www.EigRig.com
Shane Ross
on Aug 22, 2017 at 4:57:39 pm
How can a Terranex require an OS version? It's an in-between box, is it not? Or does the newest one now connect to the computer like a capture card?
And yes...you are WELL advised to get a new drive or partition with the newer OS. Newer OS versions and older software don't always mesh well.
Shane
Little Frog Post
Dan McGuire
on Aug 22, 2017 at 6:53:29 pm
I'm working on an imac. Would the new cloned drive need to be internal? Or could I boot up from a 10.10 system drive that is external, and work in FCP7 from it?
John Rofrano
on Aug 29, 2017 at 12:35:50 am
[Dan McGuire] "Would the new cloned drive need to be internal? Or could I boot up from a 10.10 system drive that is external, and work in FCP7 from it?"
The drive can be external. I would use a USB 3.0 drive. Try and find one that is 7200 RPM instead of 5400 RPM for a little additional performance.
What you do is hold the Option key when you hear the boot chime and keep it held down until you are greeted with a screen that shows all connected drives. Then just select the external drive and your iMac will boot from it. Not sure how well FCP 7 will work with 10.10 but that's why you need to keep 10.8.5 around.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
