replacing green screen color on FCP7?
raju bhai
on Aug 6, 2017 at 8:16:26 pm
Hello,
I have a bunch of shots i filmed with the band in front of a green screen for a music video. However for a few of the shots i am not chroma keying any images behind the band because i prefer the way it looks with just them in front of the green screen.
However i do want to change the color of the green background to say something like white or perhaps even a different color, just so it doesn't look so obvious that they are in front of a green screen.
I imagine this should be really easy to do. But for whatever reason, i just can't figure it out!
Michael Gissing
Re: replacing green screen color on FCP7?
on Aug 6, 2017 at 10:28:55 pm
To replace green with any other color you still need to create a key. So chroma key to a white slug or whatever color you want.
raju bhai
on Aug 7, 2017 at 12:39:25 am
hi!
Actually I am trying to AVOID USING CHROMA KEY for this. Reason being is that these particular shots won't chroma key well, so just wondering if there is a way to just select the green background and swap it with a white background for instance without using chroma key. Is that possible?
Michael Gissing
on Aug 7, 2017 at 12:51:07 am
A key is a key.
