Importing a file into Compressor from FCP7
Tom Fino
on Aug 4, 2017 at 10:57:41 pm
Trying to use the "Publish to YouTube" template in Compressor to compress a FCP7 file.
However, when I start in Compressor and use Job>Source>File to import the file, the FCP files in my hard drive aren't highlighted and can't be imported/selected.
If I start in FCP, send the project to Compressor, and then choose the "Publish to YouTube" template, it starts a new batch tab - not the tab that includes my FCP project.
Any advice would be appreciated. Thanks.
Shane Ross
Re: Importing a file into Compressor from FCP7
on Aug 5, 2017 at 2:09:22 am
Which version of Compressor? The only one you can SEND TO from FCP 7 is 3.5. Any later version and there is no such link. And what do you mean by FCP files?
Best option is to export from FCP 7 as EXPORT>QUICKTIME MOVIE. Don't recompress...and not QUICKTIME CONVERSION. Just QT movie. This will export a movie with the same settings as your sequence. That will be your master. Bring that into Compressor then to compress for YouTube
Shane
Little Frog Post
