FCP7 clips from NEXFS700 all have 00:00:00:00 as start time - appear as duplicate clips
Arturo Glass
on Apr 30, 2017 at 7:55:17 pm
This used to only happen when I would use my Sony a6000 as a B-camera where when importing clips, their individual timecode always began at 00:00:00:00 instead of in-camera timecode. Is there a setting I changed on the camera or in FCP that is causing this? It's a pain because each clips shows as a duplicate clip, but they're not. A manual, and tedious, fix could be changing the reel # of each clip, but I'm wondering what I did that caused this, so as to avoid it in the future.
Thanks.
Nick Meyers
Re: FCP7 clips from NEXFS700 all have 00:00:00:00 as start time - appear as duplicate clips
on May 1, 2017 at 12:17:05 am
sorry, i don't know that camera
how did you get the footage into FCP?
Sony may have software to deal with converting it properly, so it retains it's actually reel# and timecode
you could read the thread bellow this one.
it started as a question about match framing, but morphed into a discussion on duplicate frames and reel#s
nick
Arturo Glass
on May 1, 2017 at 4:07:54 am
I'll check out the other post.
I imported the footage using Log and Transfer directly from the SD card. What's odd is that other times this doesn't happen to me, but for some reason today it did.
