Easy Setup to 1080i 29.97 HQ shows 29.96
tpc carranza
on Apr 15, 2017 at 1:08:06 am
Im using the Easy Setup to capture to 1080i/29.97 Prores 422 HQ from an HDCAM SR. when I open the file in QT, the properties are showing the file is 29.96. Is there a setting some where that needs to change. Media info shows 29.97 and frame rate as constant. This is on a FCP version 7 using a Kona 3G card
Shane Ross
Re: Easy Setup to 1080i 29.97 HQ shows 29.96
on Apr 16, 2017 at 12:39:18 am
Quicktime is wrong. Everything else is right. QT is wrong a lot when it comes to reporting frame rates.
Shane
Little Frog Post
