Changing time code on newly redigitized clips.
Dan McGuire
on Apr 5, 2017 at 12:49:05 am
Folks, I have an SD timeline and I recently redigitized, to HD, all the original tapes.
The timecode is not identical. Here is a picture of the SD file next to the HD file.
Is there a way to re-write the TC on the new HD files to match the TC on the SD files? Thanks.
Do I need to go to the same point on both tapes - for example, where there is a camera cut, to find the difference? There isn't any slate on the footage. The same point on the SD file is 00:05:54;19 VS on the HD 00:05:57;11
THANKS
DAN
Dan McGuire
Re: Changing time code on newly redigitized clips.
on Apr 5, 2017 at 1:15:24 am
Just tried to use the FCP7 function of Modify->Timecode and it did not offer the option of a 29.97 time base - only 30fps. Why is that?
Nick Meyers
on Apr 5, 2017 at 11:29:18 pm
while FCP can change the timecode,
it can't change the time base,
you need to run the clips through Cinema Tools to "Conform" them to a new frame rate.
i never work with those frame rates myself, living in PAL land,
so there may well be other things going on i can't identify,
like did you capture the clips correctly?
nick
Dan McGuire
on Apr 6, 2017 at 12:04:14 am
Thanks. I did not know that. I will look into that.
