Logo Animation Looks Soft on Export
Jenn Belleville
on Mar 29, 2017 at 12:47:35 pm
Hi There & Thanks In Advance!!!
I'm working in FCP 7.0.3 and a 640 x 480 NTSC SD sequence. My footage is a 640 x 480 QT file. I also need to use an animated logo that is a 1920 x 1080 MPEG-4 file. This logo seems to look fine in the canvas but when I export it looks a little bit soft.
My render control is set to "always use best quality" & "best quality" in the sequence settings. I've tried exporting a number of ways but ultimately this video is for youtube so I believe I need to stick to MPEG-4.
If anyone can shed light on what I've missed it would be greatly appreciated!
Michael Gissing
Re: Logo Animation Looks Soft on Export
on Mar 30, 2017 at 2:36:48 am
I'll bet your sequence settings have defaulted to DV codec. If so then change the sequence codec settings to ProRes 422 and it will render better. DV is a horrible old legacy codec that turns graphics and text to mush
Jenn Belleville
on Mar 30, 2017 at 2:54:16 am
Thanks!! This solution has worked out great!
Much appreciated :)
JB
