Converting AVI to ProRes
Bobby Hall
on Mar 16, 2017 at 7:47:36 am
I'm trying to use MPEG Streamclip to convert some AVI files to ProRes. The problem is that the converted files are just black video with no audio. Anyone know how to fix this?
David Roth Weiss
Re: Converting AVI to ProRes
on Mar 16, 2017 at 5:39:35 pm
You really need to provide more info Bobby... Precise specs of the AVIs and ProRes files might help, as well as a screenshot of your Streamclip settings...
Also, try transcoding to DVCpro as a test... Maybe the AVIs have some issues and this would rule out ProRes issues.
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Bobby Hall
on Mar 16, 2017 at 6:46:50 pm
I believe the codec of the AVI files is H.264. In Streamclip it doesn't list the codec for some reason, but in another program I have called Pavtube iMedia Converter, it lists it as H.264. This program also allows me to convert the files to ProRes, but I don't fully trust this program. I've had issues with the color of certain files being different from the originals, so I prefer to transcode in Streamclip in possible.
The AVI files are 1024x576, 29.97 fps, mp3 audio. I want to convert them to ProRes with the same dimensions.
Bobby Hall
on Mar 16, 2017 at 6:49:59 pm
Transcoding them to DVCpro or any other codec doesn't work. I just get black video. Maybe the fact that Streamclip can't even play them means that I have to use a different program to convert them.
David Roth Weiss
on Mar 16, 2017 at 6:54:05 pm
If they don't play prior to transcoding that would indicate an issue. It could be the MP3 audio, or could be the AVI wrapper.
David Roth Weiss
Los Angeles
