Dropping Frames
Mat Arnold
Dropping Frames
on Feb 24, 2017 at 11:07:27 pm
AE here. I'm having an issue with one of our machines suddenly dropping frames when trying to playback from the timeline.
Mac Pro running 10.6 - Final Cut Pro 7
Model Identifier: MacPro4,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 2.93 GHz
Number Of Processors: 2
Total Number Of Cores: 8
L2 Cache (per core): 256 KB
L3 Cache (per processor): 8 MB
Memory: 12 GB
Processor Interconnect Speed: 6.4 GT/s
Boot ROM Version: MP41.0081.B07
SMC Version (system): 1.39f5
SMC Version (processor tray): 1.39f5
Serial Number (system): H094918E20H
Serial Number (processor tray): J594400G91LUE
Hardware UUID: FEE3A021-6878-5C45-AC95-597340FB626E
Our media is on an XSan server.
All media is in Prores 422 Proxy and the timeline is set to Prores 422 Proxy
Even if I turn off the dropped frame error message, the lag is too bad, no one can work in that bay. Was fine a week ago.
I've restarted the machine.
Deleted render files.
Switched internal scratch disks.
Switched from Safe RT to Unlimited RT.
Turned off external video.
Changed video playback settings.
Used Blackmagic Disk Speed Test on the media server, speeds are good.
Ran Onyx's maintenance utilities on the machine.
The problem persists, in any project I open, regardless of which user is signed into the machine. Those same projects play fine in our other bays, which have their Final Cut's set up identically.
Any suggestions for what I should try next?
Shane Ross
Re: Dropping Frames
on Feb 25, 2017 at 9:30:18 am
Trash preferences.
Shane
Little Frog Post
Nick Meyers
Re: Dropping Frames
on Feb 25, 2017 at 11:16:05 am
double check how you're connected to the server.
