Any benefit to 24 bit sequence settings if all audio clips originially recorded at 16 bit?
Matt Wilson
on Jan 22, 2017 at 3:30:57 am
I wondered if anyone knew if there's any benefit to changing my sequence settings from 16 bit to 24 bit if all my audio clips were originally recorded at 16 bit? Any problem switching those sequence settings from 16 to 24 in the middle of a project edit?
Matt
Shane Ross
Re: Any benefit to 24 bit sequence settings if all audio clips originially recorded at 16 bit?
on Jan 22, 2017 at 3:32:57 am
There will be no difference. Just like with AVCHD to Pro Res...making a bigger space won't make the information in it suddenly better. Only switch to 24 bit if a delivery requires 24 bit. Nothing will improve.
Shane
Little Frog Post
Matt Wilson
on Jan 22, 2017 at 3:43:09 am
Ok - thanks.
