Can I copy codecs from one machine to another?
Chris Babbitt
on Jan 13, 2017 at 4:38:05 pm
I recently bought a new iMac that I will eventually use for editing. In the meantime I am using FCP 7 on a very old Mac Pro. For now, I would like to do some file conversions and encoding on the new machine. As the Pro codecs do not come installed on new machines, can I copy those from the old machine to the new, and, if so, where do I find them?
Warren Eig
Re: Can I copy codecs from one machine to another?
on Jan 13, 2017 at 4:59:01 pm
HD / Library / Quicktime
I've copied this way.
Warren Eig
O 310-470-0905
email: info@babyboompictures.com
website: http://www.BabyBoomPictures.com
For Camera Accessories - Monitors and Batteries
website: http://www.EigRig.com
Chris Babbitt
on Jan 13, 2017 at 6:26:20 pm
Warren,
I only see a few of the codecs listed there. Are they spread out in different locations?
Warren Eig
on Jan 13, 2017 at 6:45:44 pm
Try System / Library / Quicktime.
Warren Eig
O 310-470-0905
John Rofrano
on Jan 14, 2017 at 1:47:09 pm
[Chris Babbitt] "For now, I would like to do some file conversions and encoding on the new machine. As the Pro codecs do not come installed on new machines, can I copy those from the old machine to the new, and, if so, where do I find them?"
How do you plan to do the file conversions? If you use Apple Compressor ($49) it comes with the Pro codecs. Problem solved.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Roger Poole
on Jan 17, 2017 at 12:35:08 am
Download and install Quicktime 7. That should do it.
Chris Babbitt
on Jan 17, 2017 at 1:10:51 am
For right now, I am using Clipwrap and Quicktime. I have Quicktime 7 on the system, but it doesn't come with the pro codecs.
John Rofrano
on Jan 21, 2017 at 3:57:41 pm
[Chris Babbitt] "For right now, I am using Clipwrap and Quicktime. I have Quicktime 7 on the system, but it doesn't come with the pro codecs."
Why don't you buy Compressor then? That will get you the Pro codecs that you need.
~jr
Chris Babbitt
on Jan 21, 2017 at 5:48:27 pm
I have the codecs. I just need to know where to find them and how to copy them from the old machine to the new.
John Rofrano
on Jan 21, 2017 at 6:22:05 pm
[Chris Babbitt] "I have the codecs. I just need to know where to find them and how to copy them from the old machine to the new."
Well Warren Eig already said to check here:
Macintosh HD/Library/QuickTime
Macintosh HD/System/Library/QuickTime
I also have codecs here:
Macintosh HD/Library/Video/Professional Video Workflow Plug-Ins
Not sure what codec you are looking for but those are the three places I've found codecs on my Mac.
~jr
Chris Babbitt
on Jan 23, 2017 at 5:19:40 pm
Thanks for responding, John. One of the codecs I am looking for are the XDCAM codecs, and they are not at any of those locations.
John Rofrano
on Jan 23, 2017 at 10:34:14 pm
[Chris Babbitt] "One of the codecs I am looking for are the XDCAM codecs, and they are not at any of those locations."
Have you tried manually installing Apple Pro Video Formats 2.0.4? That has support for XDCAM EX / HD / HD422 in it. Not sure if it will install without having pre-requisite software installed but it's worth a try.
~jr
