sequence setting audio sample rate for music video with canon 5d prores 422
raju bhai
on Jan 1, 2017 at 6:03:44 am
Hello and happy new year!
The sequence setting for audio defaults to 48khz since canon 5d audio is normally 48khz. However, i am cutting a music video and so i won’t be using any of the video clips’ audio. Instead i have an audio track with the song on it which is a 44khz, 16 bit wav file. Should i convert the song file to 48khz? Of course i’d prefer not to do that as this is an already professionally mastered song at 44khz and i don’t want to degrade the audio at all by up-sampling it. Preferably, i could instead just change the sequence setting from 48khz to 44? When i drop the canon 5d prores clips into my timeline, it only adds the video portion, not the audio, to the timeline, so in this case there’s no reason why i should leave the 48khz default on the sequence setting right? Or is there something i’m overlooking here?
Nick Meyers
Re: sequence setting audio sample rate for music video with canon 5d prores 422
on Jan 1, 2017 at 10:14:31 am
video is 48khz, and more oftener than not, it;s 24bit these days
your final video will be 48k, so convert your audio now, using the "Best" setting in Compressor
cheers,
nick
