Bringing a 4x3 clip into a 16x9 FCP7 Timeline without stretching. How to?
Ned Miller
on Nov 25, 2016 at 7:50:59 pm
I'm not much of an editor, I muddle through. I have a timeline for a 16x9 project in FCP7. The client provided me with legacy video in 4x3 and I wanted to add two vertical side bars but it is automatically "stretching" the image to 16x9, and my client looks like he gained 100 pounds. I can't locate any controls to allow me to keep it at 4x3. Any help is greatly appreciated!
Ned
Ned Miller
Chicago Videographer
http://www.nedmiller.com
David Roth Weiss
Re: Bringing a 4x3 clip into a 16x9 FCP7 Timeline without stretching. How to?
on Nov 26, 2016 at 12:44:56 am
First, there is a preference you can change that will not scale clips to match the timeline settings. You can find it...
Second, for the clips you may have already added to your timeline: double click the clip to load it into the viewer > click on the Motion tab > click the red X to clear the parameters and return the to their defaults, which will make your video display natively.
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Nick Meyers
on Nov 26, 2016 at 12:50:05 am
the main parameter you'd want to re-set is DISTORT.
the Basic Motion includes scale, which could be doing you some favours.
opening into the viewer needs to be done on a clip by clip basis,
but you can do multiple clips by selecting them in the timeline,
then either hit OPtion Command V
or right click on the clips and chose "Remove Attributes"
select Distortion and hit OK
nick
