Final Cut Pro 7 - video clips are shortened/accelerated upon import into browser
John Maguire
on Oct 22, 2016 at 7:07:37 pm
I am not a pro, but I'll try to explain my situation. Before importing video clips into the browser or inserting the clip into a sequence, I ensured my FCP 7 settings were correct for my video: 23.98 (23.976) etc. My video clip was verified to be a certain time length by the apple finder info, VLCplayer and Quicktime. But when it is when imported into the FCP browser, it is significantly shortened/accelerated in time, which destroys the sync to the already separate audio tracks. The audio tracks are then imported into the FCP browser, but retain their correct time lengths. I've transcoded the video to Prores 422 LT and Prores 422 HQ files in Quicktime Pro and Mpegstreamclip and the shortening/acceleration upon import happens in all cases. This problem has arisen for various users and situations over several years as described in the numerous threads below. The only potential workarounds by "Benny Krown" and “Thomas Davis” in the first thread below appear to require the double or triple transcoding of files that often are already in Prores, which is obviously a sub-optimal solution. Has anyone solved this or found any new workarounds?
https://forums.creativecow.net/thread/8/1084387
https://forums.creativecow.net/thread/8/1160685
https://forums.creativecow.net/thread/8/1132569
https://forums.creativecow.net/thread/8/1167772
https://forums.creativecow.net/thread/8/1151482
https://forums.creativecow.net/thread/8/1106140
http://originaltrilogy.com/topic/Fan-Edit-Sync-Issue-Please-Help/id/16548
https://discussions.apple.com/thread/7319047
David Roth Weiss
Re: Final Cut Pro 7 - video clips are shortened/accelerated upon import into browser
on Oct 22, 2016 at 11:48:16 pm
What is the camera original source of your media? What was the camera, what codec, what framerate? Are the files you're working with camera original, or something you're reediting?
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
John Maguire
on Oct 23, 2016 at 4:27:49 am
Original source was a two-hour MKV from a blu-ray: codec: Windows Media Video VC1 (WVC1), Frame rate: 23.976215. (I am editing one of my favorite 1980's PG movies with rough language and scenes for my young niece. Surround audio was separated into multiple mono 48khz WAV’s, so I can edit center channel dialogue.) Time length of audio and video files are the same before and after transcoding video to ProRes. FCP settings are confirmed before import into new projects. It is the import of the ProRes video clip into FCP7 that shortens/accelerates the video clip by nearly one minute. I've tried transcoding to ProRes in various ways: LT, HQ, video only, with Quicktime Pro and Mpegstreamclip, and all resultant video clips are shortened/accelerated upon import into the browser.
David Roth Weiss
on Oct 23, 2016 at 5:32:41 am
We really can't help you with this here John - you see, what you're doing is in violation of the intellectal property rights of those who own and created the film you want to edit, and it violates the code of conduct here on the Cow. Hope you understand?
David Roth Weiss
Los Angeles
Nick Meyers
on Oct 23, 2016 at 8:41:34 am
"Frame rate: 23.976215"
the frame rate seems a bit odd.
I've had luck correcting weird frame rates using cinema tools.
open the file in cinema tools, and conform the frame rate to 23.98
I've found PAVtube (or one of their many products) to be a LOT better with MKV files than any other app.
a lot faster for sure.
you can leave the audio as part of the video and all 6 tracks will come in,
and be in sync with the video.
nick
John Maguire
on Oct 24, 2016 at 1:58:08 am
Understood David.
Thanks Nick.
