Final Cut Export Different Size Than Sequence
Zach Woliner
on Oct 22, 2016 at 4:45:03 pm
Hey Everyone,
I am brand new to this community, just joining it because of this specific issue I just encountered, last night. I had captured from a mini-DV to FireWire cable, some footage from a VHS tape, to back it up digitally. In the process, I got more than just what I want to keep, so I wanted to just chop it down, a bit, in Final Cut, which I did. I exported it to a Quicktime movie, and then, I just wanted to check something, to see if it came out just the same, because of something I remembered recently encountered.
So, I imported the new export, and I layered it directly over the video in the timeline that it was exported from. When I lowered the opacity from 100-0%, hoping it remain exactly the same, as I'd expect, it did show a slight vertical stretch, instead. When looking over the sequence settings and export settings, they appeared to be the same, at 720 x 480, DVNTSC, with 48 KHz, or whatever the units were.
Does anyone know why there would be a slight difference in the appearance, vertically, like that, despite this? I am using an older program, Final Cut Pro HD. Like I said, at least as far as I can tell, the settings are the same. I just want to maintain the integrity of the original image's dimensions, and I am not sure what causes the change, or whether the original captured footage or the export is more true to the source. Thanks, in advance, for any of your feedback!
-Zach
