Settings for Authoring a Blue Ray Disk
David Mayer
on Sep 14, 2016 at 1:08:56 pm
My Blu Ray authoring work flow using FCP 7 is:
1. Export from Final Cut with Current Settings, Chapter Markers and Self Contained
2. Compressor
3. Blue Ray Burner using BD-R disks
Are the settings in number one above correct?
Dave
iMac 2.8 GHz Intel Core i7, 8 GB 1067 MHz DDR3
OS 10.10.4
Final Cut Pro 7.0.3
Compressor 4.2
DVD Studio Pro 4.2.2
Canon C100
Michael Gissing
Re: Settings for Authoring a Blue Ray Disk
on Sep 15, 2016 at 5:46:29 am
What are your current settings? What is your footage codec & pixel aspect? What codec and pixel aspect do you set with Compressor?
I can't see where you are doing the bluray authoring, setting up menus, audio encoding chapters etc?
If you have Adobe Encore you could take your FCP7 quicktime directly into Encore and have it encode and author plus control the burn to bluray. Otherwise it seems like to are perhaps making a copy of your file to a bluray Rom disk
David Mayer
on Sep 19, 2016 at 10:08:04 pm
Thanks, Michael.
I had not gotten that far.
Not sure what I need to finish the Blu Ray process.
Is Encore the best option?
I started a new thread asking about the best way to make a Blu Ray with a menu.
Dave
OS 10.10.4
Final Cut Pro 7.0.3
Compressor 4.2
Canon C100
