Weird Problem: Over Exposed areas now appear as a black blobs.
Ned Miller
on Sep 9, 2016 at 9:22:48 pm
When I was filming I knew there were certain parts of the background that were hot, over 100IRE. I have edited with it and it was fine, just blown out, and I had exported some QTs. But when I returned to the project a week later, these hot areas now appear as black blobs. Is there a setting I have inadvertently turned on that uses black blobs to indicate over 100? See this screen grab, they are the blobs on the left.
Many thanks for your advice.
Ned Miller
Chicago Videographer
http://www.nedmiller.com
jerry wise
Re: Weird Problem: Over Exposed areas now appear as a black blobs.
on Sep 9, 2016 at 11:25:39 pm
i have not used FCP7 for a few years but it might be a prefs change or a setting on the "canvas" area.
jerry wise
on Sep 11, 2016 at 4:25:47 pm
did you ever find the cause of the black blobs ?
Mark Suszko
on Sep 19, 2016 at 5:57:17 pm
They might be keying over a black under-layer?
Robert Withers
on Sep 20, 2016 at 6:01:43 pm
Not created by an early generation Black Magic Mini camera?
Robert Withers
Independent/personal/avant-garde cinema, New York City
Ned Miller
on Sep 30, 2016 at 5:10:37 pm
Bo. It does go away when I reduce the brightness filter from 1.2 to 1.1. however, it has never down this before when I added that filter.
Ned Miller
