AVI into Final Cut 7 Pro
Jean Tertrain
on Sep 6, 2016 at 2:23:05 pm
Hello everyone,
I'm new and happy to be on this forum, I hope I will be able to share the little I know. I have a little (maybe not) question about getting .AVI file into Final Cut 7 Pro. I'm editing a music video from various found footage and one of the sources is a movie which is in .AVI format. I looked on the internet and I found nothing but expensive software to do this. So I wanted to ask you pros if it was actually this bad, as almost any other format is transcodable with MPEG Streamclip.
Thank you if you can help me with this :)
Jean.
Shane Ross
Re: AVI into Final Cut 7 Pro
on Sep 6, 2016 at 5:12:05 pm
The only software I've been able to convert AVI with is Sorenson Squeeze. Compressor and MPEG STREAMCLIP wouldn't do it. Might also try Media Encoder from Adobe...
Shane
Little Frog Post
Dave Farrants
on Sep 6, 2016 at 7:43:43 pm
I regularly get .avi files to edit from a 'GoPro' type camera, they open in QT7 Pro on a 2009 MacPro (El Capitan) and it allows export to ProRes for FCP7. The machine once had FCP7 on it so the ProRes codecs and QT7 stayed on the system when I deleted it off that partition as FCP7 failed to work properly under El Capitan and I now use a second boot drive with just SL & FCP7.
Web - http://www.foxvideo.co.uk
Blog - http://foxvidpro.blogspot.co.uk/
