29.97 fps to 24 fps in FCP7 - NEED ADVICE ASAP
Ted Maynard
on Aug 15, 2016 at 6:43:48 pm
I need to convert a heavily edited 29.97 sequence to a 24fps sequence. I cannot just bring in an exported version of the film because I need to have my audio (raw+stems) available for making an AIFF to send off for mixing. Does anyone know of anyway I can do this? Any help would be greatly appreciated as I need to figure this out ASAP.
Faith
Shane Ross
Re: 29.97 fps to 24 fps in FCP7 - NEED ADVICE ASAP
on Aug 15, 2016 at 7:31:45 pm
Wait...is the ENTIRE project...all the media and the sequence setting...29.97? If so...then it's best to online and mix it at that frame rate, and then convert that master to 24fps. Is this for a DCP?
Shane
Little Frog Post
