Relinking clips that are in a different folder
Bobby Hall
on Jul 25, 2016 at 9:36:06 am
If you you have a project in FCP and you decide to rename the folder the source clips are in (or move that folder inside another folder), is it normal to have to relink each clip individually? This is happening to me. I thought you would only have to relink one and the rest would relink as long as they were all in the same folder. Is there a way to change the original path of all my files so that FCP will reconnect them automatically?
Shane Ross
Re: Relinking clips that are in a different folder
on Jul 25, 2016 at 6:57:39 pm
This is a bug that would occasionally pop up. Annoying as hell, and you need to manually relink one at a time. Ive had this happen before and it's a total pain.
Shane
Little Frog Post
Bobby Hall
on Jul 25, 2016 at 9:26:14 pm
That sucks. Well, thanks for letting me know it's a bug!
