Final Cut Pro 7.03
Roger Nissenbaum
Final Cut Pro 7.03
on Jul 19, 2016 at 8:41:02 pm
Is there a way to pull up all files used in an edited piece in FPC 7.03?
Roger
Roger
Shane Ross
Re: Final Cut Pro 7.03
on Jul 20, 2016 at 12:54:45 am
How do you mean? Link to all the clips used in a bin? ON the hard drive? You can MEDIA MANAGE them and copy over all the clips used in a sequence, yes. The full clips, or just the parts used in your cut, with handles/
Shane
Little Frog Post
Nick Meyers
on Jul 20, 2016 at 7:56:18 am
your question is a little bit vague!
if you want to get all the used clips into a new bin, copy the sequence into a new project,
then Tools Menu > Create Master Clips.
you'll get one instance of every master clip used in the timeline.
you'll also get master clips for each text (or other) generator,
so maybe clear them out first if you want.
nick
