FCP 7 source and record viewers magenta
Neal Boyle
on Jul 19, 2016 at 9:59:18 am
Hi Folks,
I used to use FCP7 (in Final Cut Studio 3) and still go to it when an older project cut with it needs to be dusted down and re-cut. So before you say 'just stop using it', I have, but having used it for years I’m quick on it and that’s the easiest way to get the job done with minimum fuss on a project that was cut with it.
The problem:
I opened it the other day, first time in about a year, and now the source and record viewers are magenta, regardless of if there’s media loaded into them or not (i.e. source media or a sequence). The actual media clips themselves are fine, I did a quick export test and the output is fine, I just can’t view it without this magenta overcast inside FCP7. I'm not getting any error messages.
Anyone any idea what this is and how to fix it?
My System:
Mac Pro (Late 2013 trash can)
Processor: 3.5 GHz 6-Core Intel Xeon E5
Memory: 16 GB 1866 MHz DDR3 ECC
Graphics: AMD FirePro D500 3072 MB
Thanks in advance,
Neal
Neal Boyle
@Neal_Boyle
iwrmedai.com
http://www.linkedin.com/in/nealboyleIWR
David Roth Weiss
Re: FCP 7 source and record viewers magenta
on Jul 19, 2016 at 10:49:25 am
Are any other apps displaying improperly? If not, try trashing FCP prefs.
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Neal Boyle
on Jul 19, 2016 at 12:45:17 pm
Hi David,
Trashed the prefs, to no effect. No other apps had a problem.
I poked about a bit and found that the apple monitor colour setting was set to ITU-R BT.709-5. Maybe the last editor I had in did that. I changed it back to Cinema Display and FCP went back to normal. So problem solved.
Thanks for the reply,
Neal
Neal Boyle
@Neal_Boyle
iwrmedai.com
