moving pictures / clips?
Sean Boaden
on Aug 8, 2015 at 1:39:48 am
so i put an image or green screen clip over my video, and its sorta stuck centered. is there any way i can move it around the place like to the side, bottom, etc?
thanks
Mark Suszko
Re: moving pictures / clips?
on Aug 10, 2015 at 7:06:41 pm
Several, but an easy one is to select the "image and wireframe" option in this window, then use the mouse to drag the center of the box, the edges of the box can be used to scale and rotate.
