Recorded GoPro at wrong speed - can I fix it?
eileen hyland
on Feb 8, 2015 at 5:25:08 pm
Very much a newbie, so excuse if a stupid question... My footage is all at 25fps but I just noticed that some extra footage i shot (on GoPro) is at 47.96fps!!! Is there anyway to get it to look ok - i don't want it as slo-mo! Also any advice re processing GoPro footage is much appreciated. I use 5DtoRGB to process my 5D files but not sure what settings I should use for the GoPro footage. Many thanks.
Mark Suszko
Re: Recorded GoPro at wrong speed - can I fix it?
on Feb 9, 2015 at 7:14:05 pm
When you get the go pro footage in the timeline, you can modify it's speed to double it, render that out, and use it any way you need.
Shane Ross
on Feb 9, 2015 at 9:44:50 pm
You can convert it with Compressor or MPEG STREAMCLIP. Keep the 48fps and it should mix fine (due to the high frame rate), or you can change the frame rate when you convert. Compressor is better for that.
Shane
Little Frog Post
