IMX-50 Format in QUICKTIME container
Pinaki Roy
on Dec 26, 2014 at 4:59:52 pm
Hi there,
Recently, for a TV broadcast show I have been sent the following technical specifications:
File Format: IMX 50
File Container: Quicktime
Video Chroma Sampling: 4:2:2
Video Resolution: 720x576 50i
Video Aspect ratio: 4:3
Audio tracks: 4
Sampling Rate: 48 kHz
Audio loudness: -10dBfs
Audio Sync: +10ms / -20ms
Now if I am not wrong (please let me know if I am), I can do this using Quicktime Conversion. But I am totally confused with the audio settings. Under the drop down of the Channels, there are only 3 options available: 1: 2 Discrete channels. 2: Mono and 3: Stereo (L+R). I need four audio tracks in the final output. I have 4 audio tracks in the timeline. Please help me out as I need to give the final output within these two days now.
Also if possible, is there any other way to export the same file format through some any other way?
Thanks in advance,
P
