[Neal Fox] "I'm using Final Cut Pro 6.8"
Tricky...FCP 6 stopped at 6.0.4. :) (sorry, snarky reply)
[Neal Fox] "Can I just make a nest of all the tracks and add one broadcast filter to that?
Or is it better to add a filter for each individual clip that needs it?"
Nesting is fine. Or a trick I learned was to export Quicktime Conversion, as the same codec. That'll make it broadcast safe without the filter. But the nesting idea is fine. Or just highlight all the clips and add it to everything. I personally hate nests...
Shane
Little Frog Post
Read my blog,
Little Frog in High Def
